Application Run Control
Use this dialog box to view and edit the device restrictions that have been added to this Application Run Control configuration. You do this when:
Note: This configuration requires an authentication configuration installed on the devices.
		This section contains the following topics and folders:
Restrictions
| Action on Device | Select the type of action you want this configuration to have on the device:
| Applications | Select Add to open the Restrictions > Applications dialog box in which you can enter the details of an application you want to restrict. |
