Restrictions > Applications
Use this dialog box to specify the device restriction you want to add to the Application Run Control list. Do this when you perform the following actions:
Target Type | Select the target type of the restriction.
Policy Type | Select the policy type of the restriction.
User or Group SID | Enter the Windows user or group security ID you want the restriction to apply to, or select a predefined user or group security ID from the list. |
Name | Enter a name used to identify the restriction. |
Description | Enter a description for the restriction. |
