Client PFX Certificates
Use a Client PFX Certificates configuration to distribute Client PFX certificates to Windows Modern devices. Do this when you perform the following actions:
You can select an existing certificate or you can select a template that SOTI MobiControl uses to dynamically generate a certificate that is specific to each user and device. For more information on how to create a certificate template, see Adding Certificates.
Note: Client PFX certificates can be used on devices running Microsoft Windows 10 or later.
Client PFX certificates installed on older devices are ignored.
Trusted Certificates
(Windows Modern Desktop) Target Certificate Store | Select whether you want the certificate to be installed in the Device store or the User store. |
Add Certificates | Select the Import button to upload a certificate to SOTI MobiControl. After the certificate is uploaded, it is displayed in the list where you can select the certificate for the profile configuration. |
