Building Signal Policy Conditions
In the Conditions tab of the Create Signal
Policy panel, select Add Condition to add
a condition to your first condition group.
Repeat step one to add more conditions as required.
Tip: Hover over the existing condition rows to edit or delete them.
If you add more than one condition, you can change the drop-down list,
X of these conditions must be satisfied, such that
X is one of the following options:
- ALL: All conditions listed must evaluate to True for the Signal Policy to trigger. This sets up an AND style condition set. For example, (Device Battery < 10% AND Device Memory < 1 GB).
- ANY: Any of the conditions listed must evaluate
to be true for the Signal Policy to trigger. This sets up an OR style
condition set. For example, (Device Battery < 10% OR Device Memory
< 1 GB).
- Select New Group to add a new group of conditions that work with those you already added. Later groups can feature different Categories.
When adding more than one group of conditions, set the Grouped
Conditions to Trigger Actions Must Include drop-down to
ANYorALLdescribed in step three.For example, for condition groups A, B, C, D, and E:- Select
ANYto set up anORstyle condition set between the condition groups: [(AANDBANDC)OR(DANDE)] - Select
ALLto set up anANDstyle condition set between the condition groups: [(AORBORC)AND(DORE)]
- Select
