WiFi (Android Classic)
General: Network
| Network Name | The name of the network which the device should connect to. This is also the name of the Wireless Policy. |
| Set as Active Network | If enabled, allows or restricts the device to connect to the WiFi
network automatically when you push the profile configuration to the
agent for the first time. Note: If you set a new WiFi profile to
Set as Active Network and assign this profile to a
device, the new profile replaces the existing WiFi profile
only if the WiFi signal strength is 'Good' or
higher. |
General: Security
| Security Type | The security protocol currently being used on the network. You can select WEP, WPA/WPA2, 802.1x Enterprise or None.
If you select the 802.1x Enterprise security protocol, the following configuration sections are displayed: In the Protocols section, you can select TLS, LEAP, EAP-FAST, TTLS, and/or PEAP. In the Authentication section, you can set the following options: Note: 802.1x WiFi is only supported on certain devices. Check Vendor Compatibility Matrix: 802.1x Enterprise WiFi for supported devices.
| Password | Enter the password required to connect to the network. |
| Proxy | SOTI MobiControl offers proxies to be automatically or manually configured. If Automatic is selected, enter a URL in the URL field. If Manual is selected, you must enter data in the Proxy Server and Exceptions fields. |
| URL | If Automatic is selected as the proxy setting, enter the URL of the proxy here. |
| Proxy Server | If Manual is selected, enter the address, and (optionally) the port number, for the proxy server. |
| Exceptions | If Manual is selected, enter any host exceptions that you want to connect directly to instead of through the proxy.
Use commas to separate host exceptions. |
