Device Functionality
Features
| Allow Camera | When enabled, device user can use the camera. Note: If
camera. Android OS compatibility: 6.0 or later. |
| Allow Smart Lock | When enabled, device users can use Smart Lock on Android
within 'safe' places that the device user sets. If you enable Allow All Keyguard Features feature control option, Allow Smart Lock is automatically enabled too. Android OS compatibility: 6.0 or later. |
capabilities. Requires Android 9.0 or later. Note: Not
| Allow Location Sharing for Work Profile | When enabled, you can Location Sharing for all Managed Profile apps. Apps running in the Work profile are unable to use device location information. |
When enabled, when a supported app launches for the first time, it skips any introductory hints or tutorials. Note: Not available on Android 11 COPE devices.
Note: Not supported for AMAPI-enrolled devices. |
| Allow All Keyguard Features | When enabled, device users can use keyguard features on the lockscreen. Keyguard features include fingerprint authentication, viewing of notifications, smart lock access and camera access. Enabling Allow All Keyguard Features automatically enables the other keyguard feature control options. |
devices. If you enable the Allow All Keyguard Features feature control option, Allow Fingerprint Authentication automatically enables too. Android OS compatibility: 6.0 or later. |
This does not remove any existing accounts from the device. Note: For AMAPI-enrolled
devices, No Accounts is the only
option available.
optimization. Note: Disabling this option
negates any battery optimizations provided by doze mode and
uses extra battery power to stay connected. Note: Not supported for AMAPI-enrolled
devices. |
| Perform SafetyNet Check on Device Check-in | When enabled, the device performs the
SafetyNet check at every device check in, in addition to once
daily. Note: Not supported for AMAPI-enrolled
devices. |
| Allow Copy/Paste between Work and Personal | When enabled, device users can copy text or images between the Work and Personal profiles. |
secure lock screens. If you enable Allow All Keyguard Features feature control option, Allow Sensitive Notifications automatically enables too. Android OS compatibility: 6.0 or later. |
| Allow Installation from Unknown Sources | When enabled, device users can install apps that are not from the Google Play store. |
| Allow Installation from Unknown Sources on Personal | When enabled, device users can install apps that are not from the Google Play store on the personal profile of the device.
Supported on Android 10.0 or later. |
| Allow Sharing from Work Profile to Personal | When enabled, device users can use an app's Share function to share between apps on the Work profile to apps on the Personal profile.
Android OS compatibility: 5.1.1 or later. |
| Allow Bluetooth Contact Sharing | When enabled, device users can use Bluetooth to share contact information.
| Allow Backup Service | When enabled, device users can turn control whether
the backup service (which managers both backup and restore
services) is turned on or off. Note: Not supported for
Policy Messaging
Restriction Policy
This action is disabled by SOTI MobiControl. Contact your organization's administrator to
learn more.Android OS compatibility: 7.0 or later.
Device Admin Description
Work Profile Wipe Message
Enter the message that should appear to device users when the Android Work Profile is wiped of its data and removed from the device.
Android OS compatibility: 9.0 or later.
