Device Functionality
Features
| Allow Camera | When enabled, device user can use the camera. Note: If
camera. Android OS compatibility: 6.0 or later. |
| Allow Factory Reset | When enabled, device users can erase all applications,
settings and data from the phone's internal storage. Note: Not
| Allow Safe Boot | When enabled, you can reboot devices into safe boot mode.
However SOTI MobiControl disables third-party
software in safe boot. Android OS compatibility: 6.0 or later. Note: Not supported for AMAPI-enrolled
devices. |
| Allow Smart Lock | When enabled, device users can use Smart Lock on Android
within 'safe' places that the device user sets. If you enable Allow All Keyguard Features feature control option, Allow Smart Lock is automatically enabled too. Android OS compatibility: 6.0 or later. |
| Allow SMS | When enabled, the device can send and receive SMS. |
| Stay Awake while Charging | Determines who controls if the device remains
awake while it is charging.
Note: Not supported for AMAPI-enrolled devices. |
| Allow Status Bar | When enabled, you can expand the status bar to view the
details of device notifications. Android OS compatibility: 6.0 or later. |
| Allow Keyguard Camera | When enabled, the device user can launch the camera
| Allow Microphone | When enabled, the device user can use the device microphone to record audio. |
| Allow Airplane Mode | When enabled, device users can turn on Airplane mode
on the device. Requires Android 9.0 or later. |
| Allow Ambient Display | When enabled, device users can turn on the Ambient
Display feature. Requires Android 9.0 or later. |
| Allow Device Volume | When enabled, the volume settings are visible to and
changeable by the device user. Requires Android 9.0 or later. |
capabilities. Requires Android 9.0 or later. Note: Not
| Allow Certificate Management | When enabled, device users can configure stored credentials (certificates) in the device's settings. |
| Allow App Management | When enabled, device users can configure or uninstall apps (and app data). This includes disabling the ability to force close an app, clear app data, app caches, and app default launch settings. |
| Allow Outgoing Cellular Phone Calls | When enabled, device users can not perform outbound calls. Internet or Voice-over-IP (VoIP) are not blocked. |
When enabled, when a supported app launches for the first time, it skips any introductory hints or tutorials. Note: Not available on Android 11 COPE devices.
| Location Accuracy | Determines the accuracy of the location reporting data
and who controls that accuracy.
devices. |
| Allow Date Time Management | When enabled, device users can configure the date
time, and timezone settings on the device. Available on Android 9.0 or later. |
| Allow Screen Timeout Management | When enabled, device users can configure
screen timeout settings on the device. Available on Android 9.0 or later. Note: Not available on Android 11 COPE
devices. Note: Not supported for AMAPI-enrolled
devices. |
| Allow Brightness Configuration Management | When enabled, device users can configure
brightness settings on the device. Available on Android 9.0 or later. Note: Not available on Android 11 COPE
devices.
Connectivity
Network Connections
| Allow Tethering Management | When enabled, device users can configure their
device's tethering (sharing a mobile device's data connection
with another device) settings. Available on Managed Device only. |
| Allow Bluetooth Management | When enabled, device users can configure their
device's Bluetooth settings. Available on Managed Device only. |
| Allow WiFi Management | When enabled, device users can configure WiFi
configurations in their device's settings. Available on Managed Device only.
| Allow VPN Management | When enabled, device users can configure their
device's VPN settings. Available on Managed Device only. |
| Allow Network Settings Reset | When enabled, device users can reset their
network configurations from their device's settings.
Android OS compatibility: 6.0 or later. Available on Managed Device only. Note: Not supported for
| Minimum WiFi Security Level | Set the minimum WiFi Security Level that the device
can connect to. For example, if you set the minimum WiFi
security level to WPA, the device would not be able to connect
to a WEP network. Available on Managed Device only. |
| Data Roaming | Determines who controls the data roaming settings on the
device.
| Bluetooth | Determines who has control over the Bluetooth setting of the
device.
Available on Managed Devices only Note: Not supported for AMAPI-enrolled devices. |
Security Options
| Allow All Keyguard Features | When enabled, device users can use keyguard features on the lockscreen. Keyguard features include fingerprint authentication, viewing of notifications, smart lock access and camera access. Enabling Allow All Keyguard Features automatically enables the other keyguard feature control options. |
devices. If you enable the Allow All Keyguard Features feature control option, Allow Fingerprint Authentication automatically enables too. Android OS compatibility: 6.0 or later. |
| Allow All Keyguard Notifications | When enabled, all notifications on secure
This does not remove any existing accounts from the device. Note: For AMAPI-enrolled
devices, No Accounts is the only
option available.
optimization. Note: Disabling this option
negates any battery optimizations provided by doze mode and
uses extra battery power to stay connected. Note: Not supported for AMAPI-enrolled
devices. |
| Allow All System UI | When enabled, system UI alerts appear to device users.
This includes toast messages, phone activities (including
priority) system alerts, system errors and system overlays.
Available on Managed Devices only. Note: Not supported
| Perform SafetyNet Check on Device Check-in | When enabled, the device performs the
SafetyNet check at every device check in, in addition to once
daily. Note: Not supported for AMAPI-enrolled
devices. |
secure lock screens. If you enable Allow All Keyguard Features feature control option, Allow Sensitive Notifications automatically enables too. Android OS compatibility: 6.0 or later. |
| Allow Installation from Unknown Sources | When enabled, device users can install apps that are not from the Google Play store. |
| Allow Multi-User Control | When enabled, device users can add secondary users or remove added secondary users. |
| Allow Mounting Physical External Media | When enabled, device users can mount
physical external media (including SD cards) to their devices.
Note: This does not disable external media through the
device's charging port. See Allow USB File
Transfer and USB Storage.
| USB Debugging | Determines who controls the device's ability to enter USB Debugging Mode.
| Allow USB File Transfer and USB Storage | When enabled, device users can transfer data
SOTI MobiControl enables this option by default. Note: AMAPI-enrolled devices has deprecated the
usbMassStorageEnabled property. |
| Allow Backup Service | When enabled, device users can turn control whether
the backup service (which managers both backup and restore
services) is turned on or off. Note: Not supported for
Policy Messaging
Restriction Policy
This action is disabled by SOTI MobiControl. Contact your organization's administrator to
learn more.Android OS compatibility: 7.0 or later.
Device Admin Description
