VPN: F5 SSL
The F5 SSL VPN profile configuration enables you to configure F5 SSL VPN settings for devices when:
| VPN Name | Enter the name of the VPN connection |
| VPN Server Host Address | Enter the server hostname or IP address of the VPN connection |
| Domain | Enter the domain of the VPN connection |
| Username | Enter the username for authenticating the connection. You can use macros such as %EnrolledUser_Upn%, %EnrolledUser_Domain%, or %EnrolledUser_Username% . |
Authentication
| Authentication Type | Select the type of authentication used for this VPN connection. You can select Password or Certificate |
| Password | If Password is selected, enter the password used for authentication |
| Identity Certificate | If Certificate is used, select the certificate used for identity from the dropdown list. |
Client Settings
| FIPS-mode | Select the check box to enable FIPS (Federal Information Processing Standard) 140-2. |
