Settings Manager
The Settings Manager app enables you to provide controlled access to a subset of device settings while a device is in lockdown mode. Choose from the device settings below when configuring the Settings Manager app using the Settings Manager profile configuration. You do this when:
Display
Setting in Profile Configuration Description Setting In XML Configuration
Adaptive Brightness When enabled, the device user can control the adaptive brightness setting for their device. brightnessSeek
Brightness When enabled, the device user can set the brightness level of their display. brightnessAuto
Screen Rotation When enabled, the device user can decide if their display remains in Portrait mode persistently or rotates automatically as the device changes position. AutoRotate
Screen Timeout When enabled, the device user can set a period after which the device screen times out and goes to sleep. screenTimeout
Sound
Ringtone Volume When enabled, the device user can control the volume of the ringtone on their device. ringtoneVolume
Media Volume When enabled, the device user can control the volume of any media they play on their device. mediaVolume
Notification Volume When enabled, the device user can modify the volume of their device's notifications. notificationVolume
System Volume When enabled, the device user can control the volume of their device. systemVolume
WiFi
Enable When enabled, the device user has access to WiFi connectivity settings. wifiOnOff
Scan When enabled, the device can scan for available WiFi networks. wifiScan
Add When enabled, the device user can add new WiFi networks. wifiAdd
Modify When enabled, the device user can modify the WiFi network settings. wifiModify
Bluetooth
Enable When enabled, the device has access to Bluetooth. btOnOFf
Visible When enabled, the device is visible to other Bluetooth enabled devices. btMakeVisible
Pair When enabled, the device can pair with other Bluetooth enabled devices. btPairUnpair
Scan When enabled, the device can scan for other visible Bluetooth enabled devices. btScan
Time Zone
Enable When enabled, the device has access to Time Zone. timeZoneOnOff
Manual Sync to SNTP server When enabled, the device can synchronize with the SNTP server to manually update the date and time. syncWithSntpServer
SNTP Server The device can synchronize and update the date and time according to the defined server. sntpServer
