Application Run Control (Android Enterprise Work Profile)
The Application Run Control configuration enables you to create blacklists that specify which applications are prevented from running on devices. See Application Run Control: Blacklisted Applications. You perform this configuration when:
Restrictions
Click Add to create a list where you can specify the applications that you are blacklisting. You can create multiple lists and choose which ones to send to which devices.
All blacklists in the SOTI MobiControl instance are available to use in each application run control profile configuration. After creating a list, you send it to a device by enabling it using its toggle. You can also edit, delete, or export lists to a .csv file. Exported files can be imported into other SOTI MobiControl instances.
