Phone Calls
Use the Phone Calls configuration to control which phone numbers a device is able to place outgoing calls to or receive incoming calls from. You perform this configuration when:
To add a new list of phone numbers to block, click Add. Existing lists will appear in the Phone Calls list where you can enable, edit, or delete them.
Notify Server When Call is Blocked | Records all incoming and outgoing blocked calls to the server log. |
Notify Device User When Call Blocked | Displays a message to the device user when a call from a blocked phone number is received. |
