Managed Google Play
The Managed Google Play feature enables you to control how device users update Managed Google Play apps on their devices. You perform this configuration when:
Application Updates
Application Updates | Select an option to determine if and when device users can update their Managed Google Play apps:
Maintenance Window
This section is available for Work Managed and Work Profile devices.
Maintenance Window |
Turn on the toggle to enable definition of the maintenance window. Within this window, the following requirements for Google app updates will be ignored:
Note: The device will be able to get app updates outside the maintenance window while meeting the above requirements.
Starting | Set the start time for the maintenance window. |
Ending | Set the start time for the maintenance window. |
Application Feedback
Application Feedback | Enable this option to collect feedback logs from Managed Google Play applications pushed through SOTI MobiControl. |
