VPN: NetMotion
The NetMotion VPN profile configuration enables you to configure NetMotion VPN settings for devices.
VPN Name Enter a name for this VPN connection. The name cannot contain spaces or special characters.
VPN Server Hostname / IP Address Enter the hostname or IP address for your VPN server.
Username Enter a username.
You can use the following macros to specify usernames: %ENROLLEDUSER_UPN%, %ENROLLEDUSER_DOMAIN%, %ENROLLEDUSER_USERNAME%.
Domain Enter the domain that authenticates your VPN connection
Authentication
Authentication Type Select the authentication method that this VPN connection uses.
Password Enter a password that authenticates the connection on the devices.
Identity Certificate Select the identity certificate used to authenticate with the VPN server.
