Device Functionality
Features
Allow Camera | When enabled, device user can use the camera.
Android OS compatibility: 6.0 or later. |
Allow Screen Capture | When enabled, device users can save images or recordings of the device's display. |
Allow Factory Reset | When enabled, device users can erase all applications, settings and data from the phone's internal storage. |
Allow Safe Boot | When enabled, devices can be rebooted into safe boot mode. All third-party software is disabled in safe boot.
Allow Smart Lock | When enabled, device users can use Smart Lock on Android which allows devices to unlock without a password when they are within 'safe' places that the device user sets.
If the Allow All Keyguard Features feature control option is enabled, Allow Smart Lock is automatically enabled too. Android OS compatibility: 6.0 or later. |
Allow SMS | When enabled, the device can send and receive SMS. |
Stay Awake while Charging | Determines who controls if the device remains awake while it is charging.
Allow Status Bar | When enabled, the status bar can be expanded to view the details of device notifications.
Allow Keyguard Camera | When enabled, the device user can launch the camera app from the lock screen.
If the Allow All Keyguard Features feature control option is enabled, Allow Keyguard Camera will be automatically enabled too. |
Allow Microphone | When enabled, the device user can use the device microphone to record audio. |
Allow Airplane Mode | When enabled, device users can turn on Airplane mode on the device.
Requires Android 9.0 or later. |
Allow Ambient Display | When enabled, device users can turn on the Ambient Display feature.
Allow Device Volume | When enabled, the volume settings are visible to and changeable by the device user.
Allow Printing | When enabled, device users can use the device's printing capabilities.
Allow Certificate Management | When enabled, device users can modify stored Credentials (Certificates) in the device's settings. |
Allow App Management | When enabled, device users can modify or uninstall apps (and app data). This includes disabling the ability to force close an app, clear app data, app caches, and app default launch settings. |
Allow Outgoing Cellular Phone Calls | When enabled, device users cannot initiate outbound calls. Internet or Voice-over-IP (VOIP) are not blocked. |
Allow Skip App First Use Hints |
When enabled, when a supported app launches for the first time, it will skip any introductory hints or tutorials. Note: Not available on Android 11 COPE devices. |
Location Accuracy | Determines the accuracy of the location reporting data and who controls that accuracy.
Allow Date Time Management | When enabled, device users can modify the date time, and timezone settings on the device.
Available on Android 9.0 or later. |
Allow Screen Timeout Management | When enabled, device users can configure screen timeout settings on the device.
Available on Android 9.0 or later. Note: Not available on Android 11 COPE devices. |
Allow Brightness Configuration Management | When enabled, device users can configure brightness settings on the device.
Connectivity
Network Connections
Allow Tethering Management | When enabled, device users can modify their device's tethering (sharing a mobile device's data connection with another device) settings.
Allow Bluetooth Management | When enabled, device users can modify their device's Bluetooth settings.
Allow WiFi Management | When enabled, device users can modify WiFi configurations in their device's settings.
Allow VPN Management | When enabled, device users can modify their device's VPN settings.
Allow Network Settings Reset | When enabled, device users can reset their network configurations from their device's settings.
Minimum WiFi Security Level | Set the minimum WiFi Security Level that the device can connect to. For example, if you set the minimum WiFi security level to WPA, the device will not be able to connect to a WEP network.
Data Roaming | Determines who controls the data roaming settings on the device.
Bluetooth | Determines who has control over the Bluetooth setting of the device.
WiFi | Determines who controls the WiFi connection.
Security Options
Allow All Keyguard Features | When enabled, device users can use keyguard features on the lockscreen. Keyguard features include fingerprint authentication, viewing of notifications, smart lock access and camera access. Enabling Allow All Keyguard Features will automatically enable the other keyguard feature control options. |
Allow Fingerprint Authentication | When enabled, device users can use Google's fingerprint authentication framework to secure their devices.
If the Allow All Keyguard Features feature control option is enabled, Allow Fingerprint Authentication will be automatically enabled too. Android OS compatibility: 6.0 or later. |
Allow All Keyguard Notifications | When enabled, all notifications on secure lock screens are visible.
If the Allow All Keyguard Features feature control option is enabled, Allow All Notifications will be automatically enabled too. |
Allow Account Creation | Specify whether device users can add new accounts to the device. Choose an option from the dropdown list
Allow Doze Mode | When enabled, allows the device to restrict the SOTI MobiControl Android agent for battery optimization.
Always On VPN | Direct all network traffic on the device through a specified VPN.
Allow All System UI | When enabled, system UI alerts appear to device users. This includes toast messages, phone activities (including priority) system alerts, system errors and system overlays.
Allow Verify Apps Enforcement | When enabled, the device user can change the Scan device for security threats option within the Play Protect settings of the Google Play Store. |
Perform SafetyNet Check on Device Check-in | When enabled, the SafetyNet check is performed on the device at every device check in, in addition to once daily. |
Allow Sensitive Notifications | When enabled, notifications from Android Enterprise Apps display all their details when they appear on secure lock screens.
If the Allow All Keyguard Features feature control option is enabled, Allow Sensitive Notifications will be automatically enabled too. Android OS compatibility: 6.0 or later. |
Allow Uninstallation of Managed Applications | When enabled, device users can uninstall any managed applications. |
Allow Third Party Input Methods | When enabled, device users can enable additional third-party input methods such as keyboards on their devices. |
Allow Caller ID Information for Work Profile Contacts | When enabled, device user can see Caller ID information for calls from contacts saved within the Work profile. |
Allow Installation from Unknown Sources | When enabled, device users can install apps that are not from the Google Play store. |
Allow Multi-User Control | When enabled, device users can add secondary users or remove previously added secondary users. |
Allow Mounting Physical External Media | When enabled, device users can mount physical external media (including SD cards) to their devices.
Note: This does not disable external media through the device's charging port. To accomplish that, use Allow USB File Transfer and USB Storage.
Allow Outgoing NFC | When enabled, devices users can use NFC to send data (only applies to apps in the Work Profile). |
USB Debugging | Determines who controls the device's ability to enter USB Debugging Mode.
Allow USB File Transfer and USB Storage | When enabled, device users can transfer data using a USB connection or save to a USB storage device.
This option is enabled by default. |
Allow Backup Service | When enabled, device users can turn control whether the backup service (which managers both backup and restore services) is turned on or off. |
Policy Messaging
Restriction Policy
Device Admin Description
