Email: Exchange Active Sync
The Exchange Active Sync email configuration enables you to configure Microsoft Exchange email settings for your devices.
Connection
Account Name | Specify Account Name or Description |
User | Active Directory User. The following characters cannot be entered here: / \ [ ] : ; | = + * ? < > " @ |
Domain | Network domain name. |
Server | IP Address or hostname for the Exchange server.
Note: This field is case-sensitive.
Server Path Prefix | Prefix to be added to server path. Optional. |
Client Certificate | Select the client certificate from the list. |
Sync the Past | Synchronize all calendar entries for the future, and for the past specified amount of time. |
Sync Interval | Frequency of synchronization. |
Allow HTML | Allow email in HTML format. |
Email Size | Maximum amount of data for email message body to fetch during synchronization. |
Email Configuration | Specify the email address for the device. Supports macros. |
Sender Name | Specify the name of the Exchange account. |
Signature | String to be used as the signature of the sender. |
Email Notification | Choose what to do for email notification. |
Security | Choose whether to use none, SSL or TLS security |
Common Access Card Authentication | Select this option to enable Common Access Card for authentication. |
Calendar
Sync Calendar | Synchronize all calendar entries for the future, and for the past specified amount of time. |
Synchronization
Always Sync | Always sync or use sync schedule specified. |
Peak Start Time | Specifies the beginning peak service period for peak days. |
Peak End Time | Specifies the end peak service period for peak days. |
Peak Schedule | Peak schedule Synchronization frequency during peak times. Select 'As items arrive' for real-time email delivery. |
Off-peak Schedule | Synchronization frequency outside of peak times. Select 'As items arrive' for real-time email delivery. |
Peak Days - Sunday | Select to include this day in the peak time schedule. |
Peak Days - Monday | Select to include this day in the peak time schedule. |
Peak Days - Tuesday | Select to include this day in the peak time schedule. |
Peak Days - Wednesday | Select to include this day in the peak time schedule. |
Peak Days - Thursday | Select to include this day in the peak time schedule. |
Peak Days - Friday | Select to include this day in the peak time schedule. |
Peak Days - Saturday | Select to include this day in the peak time schedule. |
While Roaming | Select this option to maintain automatic synchronization even when the device is using a roaming data service. |
