VPN: Enterprise Premium
The Enterprise Premium VPN profile configuration enables you to configure Enterprise Premium VPN settings for devices.
VPN Name The descriptive name of the VPN connection.
VPN Server Host Address The hostname or IP address of the VPN server.
Backup Server Enable failover to the backup VPN server in case the primary VPN server fails to respond.
Backup Server Address The hostname or IP address of the backup VPN server.
Username The username for authenticating the VPN connection.
Password The password for authenticating the VPN connection.
Authentication
IKE Version The IKE (Internet Key Exchange) version used for the VPN connection.
Mobike Enable MOBIKE (IKEv2 Mobility and Multihoming Protocol) for the VPN account if IKE version 2 is selected.
Authentication Type The type of authentication to be used.
Pre-shared Key The pre-shared key for this VPN connection.
IPSec User Certificate The user certificate used to authenticate against the IPSec VPN server.
IPSec CA Certificate The CA certificate used to verify the IPSec VPN server.
IKE Phase 1 Exchange Mode Select the IKE phase 1 exchange mode.
Prefect Forward Secrecy Use prefect forward secrecy for authentication.
IKE Identity The IPSec group ID type for the connection profile.
Group Name The IPSec group ID type value for the connection profile.
Suite B Type The Suite B type for the VPN connection.
Diffie-Hellman Group The Diffie-Hellman group for the connection profile.
Split Tunnel Type The Split Tunnel type for the VPN connection.
Common Access Card Authentication Use Common Access Card (CAC) for authentication.
Client Settings
Dead Peer Detection Enable detection of dead peer VPN connections.
Default Routing Use this connection as default routing.
User Authentication Use device user authentication.
Enable Smart Card Authentication Use smart card authentication for this VPN account.
FIPS-mode Use FIPS-mode for this VPN connection.
