The F5 SSL VPN profile configuration enables you to configure F5 SSL VPN settings for devices.
VPN Name |
Enter the name of the VPN connection |
VPN Server Host Address |
Enter the server hostname or IP address of the VPN connection |
Domain |
Enter the domain of the VPN connection |
Username |
Enter the username for authenticating the connection. You can use macros such as %EnrolledUser_Upn%, %EnrolledUser_Domain%, or %EnrolledUser_Username% . |
Authentication
Authentication Type |
Select the type of authentication used for this VPN connection. You can select Password or Certificate |
Password |
If Password is selected, enter the password used for authentication |
Identity Certificate |
If Certificate is used, select the certificate used for identity from the dropdown list. |
Client Settings
FIPS-mode |
Select the check box to enable FIPS (Federal Information Processing Standard) 140-2. |
