SOTI Hub
SOTI Hub is a secure repository that allows organizations to control how employees access and share enterprise content outside of the corporate network.
Administrators set up a repository to share files with their device users. Device users can then use the SOTI Hub app to access those files.
SOTI Hub is compatible with devices running Android 4.1 or later and Apple devices running iOS 8 or later.
Setting up SOTI Hub
Complete the following steps to configure your environment for use with SOTI Hub.
Set up a repository for your enterprise content
A content repository stores any enterprise content that your device users access through SOTI Hub. You can use a WebDAV server or SharePoint 2013 (On Premise) server (or a WebDAV-enabled SharePoint server) as your content repository.
If you choose to use a WebDAV server, it must be an NTFS file server that is accessible via an Internet Information Services (IIS) for Windows WebDAV server. Go to Setting Up a WebDAV Server for instructions.
If you choose to use SharePoint server, it must be SharePoint 2013 (On Premise). Go to Using SharePoint with SOTI Hub for more information.
[Optional] Route your traffic through a proxy server
You can force all network traffic to and from your content repository to go through a proxy server using an Enterprise Resource Gateway (ERG). Go to Setting Up the Enterprise Resource Gateway for more information.
ERG is not supported on SharePoint.
Install SOTI apps Server Extension
The SOTI apps Server extension adds additional functionality to SOTI Hub such as Download Resumption and Intermittent Search. Go to SOTI Apps Server Extension for SOTI Hub for more information.
SOTI apps Server extension is supported on WebDAV servers.
Distributing SOTI Hub to your devices
Once you have completed the previous steps, you can deploy the SOTI Hub app to your devices and use a profile configuration to link your enterprise content to your devices and configure the app as needed. Go to Distributing SOTI Hub for more information.
Additional SOTI Hub Features
SOTI Hub provides the following features to provide security and ease of use to your users.
App Settings configuration
The SOTI Hub profile configuration provides options to customize your SOTI Hub app to your circumstances. Options include setting an inactivity timeout and how frequently devices refresh content.
See SOTI Hub Settings for further details on changing settings for the SOTI Hub app.
Download Resumption
If your devices disconnect from the network while a download is in progress, the download resumption feature continues the download from the point of disconnect when the network comes back online ensure optimal network data usage. Download resumption allows for three attempts to complete the file download. If the download is not finished within three attempts, the device user must re-initiate the download.
This features is not compatible with content repositories using SharePoint because it requires the SOTI apps Server extension. See SOTI Apps Server Extension for SOTI Hub for more information.
Note
Download resumption is triggered only when the download was interrupted by a network connectivity problem. If the SOTI Hub app closes or the device user logs out of the app, all in-progress downloads are cancelled.
LDAP Authentication
SOTI Hub supports authentication using LDAP. If you have set up LDAP authentication on your content repository, your device users will have to enter their credentials to access your repository. See SOTI Hub Settings for more specific options regarding authentication.
Offline Functionality
The SOTI Hub app retains some limited functionality when the device has no network connection or the content repository is offline. Disconnected device users are still able to view any downloaded or cached files and folders. Depending on your SOTI app configuration settings, device users can log into the app if their password matches the cached value of the field.
Search on Server
Search on server allows device users to search all the content available on the repository from their device. Intermittent search expedites the process by returning search results as they are found rather than when the full search is complete.
The SOTI apps Server extension is required for intermittent search.
If you have applied a filter to limit which file types your devices users can see on the content repository (see Content Repository Settings), the filter will continue to apply when they are conducting a search.
SOTI Hub Actions
Administrators can block access to SOTI Hub content or wipe cached SOTI Hub data for specific devices or device groups without affecting or reassigning the profile configuration. See Android+ Actions and iOS Actions for more information. A log event is created and noted whenever an action is implemented. You can view the Device log event in the Log subsection of the Information panel on the Devices tab.
© SOTI Inc.
Contact us
