You can use SharePoint as a repository for your enterprise content accessible through SOTI Hub. SOTI Hub is an app that functions as a secure portal through which your device users can safely access corporate documents. SOTI Hub is compatible with SharePoint 2013 (On Premise) or later.
IT administrators do not have to complete any additional work on the SharePoint server side to integrate it with SOTI Hub. Simply follow the instructions for linking a content repository to MobiControl at SOTI Hub Settings, select SharePoint 2013 (On Premise) from the Repository Type dropdown and fill in the fields as necessary.
You can also use a WebDAV server for your content repository. See Setting Up a WebDAV Server for more information.
