Using Live Support for Technicians
Support technicians can start a live support session from four places:
- SOTI MobiControl
- SOTI Connect Incident Management
- SOTI XSight Operational Intelligence
- Live Support Chat container
Note: For each of these options, Chat settings define the type of chat available
(text, audio, or video).
Starting from SOTI MobiControl
Note: To use Live Support Chat from SOTI MobiControl, you must have SOTI MobiControl
version 15.7 or higher.
From SOTI MobiControl, select the
hamburger menu.
Select Devices.
Locate the device you would like to open a chat with. From the device
options, select
Contact Device. The Contact
Device pop-up opens.
Select the type of chat to open.
Starting from SOTI XSight Incident Management
Select the SOTI XSight icon, and select
Incident Management.
- Within the incident dashboard, select an incident to resolve. The Incident Details view opens.
- From the Incident Details list, scroll to Devices.
Locate the device you would like to open a chat with. Select chat, followed by the type of chat
to open.
Starting from SOTI XSight Operational Intelligence
Operational Intelligence.
- From the Analysis Profile view, select the device's profile.
From the profile, scroll to the Devices list.
Within the profile, select the device you would like to chat with. Select
chat.
Starting from Live Support Chat Container
From the Live Support Chat container, select
maximize.
- Optional:
Use the search bar to find a device. Select from the available
results.
- Optional:
Select a device to rejoin from a list of active Live Support
Chat sessions.
Note: Support technicians can have many concurrent open sessions but can only communicate with one device user at a time.
