Configuring Global Settings
Note: You must log into SOTI XSight as an administrator to change
settings.
To change SOTI XSight global settings:
On the menu bar, select the menu button
and select Settings. The SOTI XSight Settings view opens.
- Select the Global button at the top of the page. The available global settings appear.
- On the left side of the Settings view, select the settings type to change. The current settings are on the right side of the Settings view.
- Make the required settings changes on the right side of the Settings view. As soon as you change a setting, SAVE and CANCEL buttons appear at the bottom of the view.
- Select the SAVE button to save the settings changes.
When your changes are complete, you may return to the incident dashboard by
selecting the SOTI XSight title on
the menu bar.
Note: You may need to log out of SOTI XSight and log back in for the settings changes to take effect.
