Integration Settings
This page displays the settings used to integrate SOTI XSight with SOTI MobiControl.
Default Instance The name of the default SOTI MobiControl instance that SOTI XSight is integrated with.
Access URL The URL of the default SOTI MobiControl instance.
Client ID The client ID of the default SOTI MobiControl instance.
Service User is enabled|disabled Select this option to enable SOTI XSight to perform an LDAP lookup in SOTI MobiControl for the incident reporter's details when an incident is created by an inbound email.
When you enable this option you must supply a valid SOTI MobiControl username and password.
Username Enter a valid SOTI MobiControl username.
Password Enter the password for the above SOTI MobiControl username.
Enable SOTI XSight Login Page Select this option to enable SOTI XSight to use its native login page instead of integrating with SOTI MobiControl single sign on (SSO) authentication. This allows you to run SOTI XSight and SOTI MobiControl on different networks.
A video demonstrating how to enable the SOTI XSight login page is available below.
You must enable the SOTI XSight login page to associate additional SOTI MobiControl instances.
Domains Enter the domain or domains you want to use for the SOTI XSight login page. The SOTI XSight login page at any of these domains will log into this instance of SOTI XSight.
Other Instances Lists other SOTI MobiControl instances that have been added to SOTI XSight.
To add a new SOTI MobiControl instance, click Add button to open the Add SOTI MobiControl dialog box.
A video demonstrating how to set up multiple SOTI MobiControl instances in SOTI XSight is available below.
Note: This section appears only when the Enable SOTI XSight Login Page option is selected.
Automatically create an incident when remote controlling a device from SOTI MobiControl Select this option to have an incident created automatically when you initiate a device remote control session in SOTI MobiControl.
Add API Clients Lists the API clients that have been added to SOTI XSight.
To add a new client, click the green + button to open the Add API Client dialog box.
How to Enable the SOTI XSight Login Page [VIDEO]
How to Set Up Multiple SOTI MobiControl Instances In SOTI XSight [VIDEO]
How to Set Up Multiple SOTI MobiControl Instances in SOTI XSight
