Integrating SOTI XSight with SOTI MobiControl
This page displays the settings used to integrate SOTI XSight with SOTI MobiControl.
Setting | Description |
Default Instance | The name of the default SOTI MobiControl instance that SOTI XSight is integrated with |
Access URL | The URL of the default SOTI MobiControl instance |
Client ID | The client ID of the default SOTI MobiControl instance |
Username | Enter a valid SOTI MobiControl username |
Password | Enter the password for the above SOTI MobiControl username |
Enable SOTI XSight Login Page | Select this option to enable SOTI XSight to use its native login page instead of integrating with SOTI MobiControl single sign on (SSO) authentication. This allows you to run SOTI XSight and SOTI MobiControl on different networks. You must enable the SOTI XSight login page to associate additional SOTI MobiControl instances |
Domains | Enter the domain or domains you want to use for the SOTI XSight login page. The SOTI XSight login page at any of these domains log into this instance of SOTI XSight |
Other Instances | List of other SOTI MobiControl instances added to SOTI XSight. To add a new SOTI MobiControl instance, click the grey + button to open the Add SOTI MobiControl dialog box. NOTE: This section appears only when the Enable SOTI XSight Login Page option is selected |
Automatically create an incident when remote controlling a device from SOTI MobiControl | Select this option to have an incident created automatically when you initiate a device remote control session in SOTI MobiControl |
Next steps: Create tags
