Gathering Operational Intelligence
SOTI XSight Operational Intelligence provides deep insight into the performance of your entire device fleet from a single screen. Pre-configured device analytics and interactive charts let you quickly analyze the following:
Information can be viewed on a group level or for a single device, and each dashboard can be customized to show metrics that are directly relevant to you. Using the cascading, interactive charts, you can isolate devices of interest within a dashboard and quickly identify the root cause of mobile device and app issues. You can also create watchlists to monitor devices and proactively address issues before they become larger problems.
Before you can begin analyzing data, first create an analysis profile and then generate and deploy the agent.
