Analyzing Location Signal Strength
The Signal Strength dashboard displays a map showing the signal strength of the devices' cellular carriers based on network carrier and type.
To open the Signal Strength dashboard, select Signal Strength from the dashboard dropdown menu.
![Last Location Dropdown](../media/images/screencaptures/signal_strength_dashboard_dropdown.png)
Select a time and date range from the menu to view signal strength. Click on a pin to open the single device dashboard and view all devices associated with the pin.
![Last Location Dashboard](../media/images/screencaptures/signal_strength_dashboard.png)
The following signal strength charts can be displayed or hidden by clicking on the icon.
Dashboard | Description |
Top manufacturers | lists device signal strength by manufacturer |
Top models | lists device signal strength by model type |
Top OS versions | lists device signal strength based on operating system |
Network generation | lists device signal strength by network generation |
Network SSID | categorized by Wifi SSID |
Mobil carriers | lists device signal strength by carrier |
Carrier signal strength | lists device signal strength by signal strength of carrier |
Graphical map | visual representation of device signal strength based on latitude/longitude data. You can switch between map and pin view |
