Using Indoor Location
The Indoor Location feature uses Wi-Fi positioning to locate the current location of your devices within a specified area, and where they have been over time.
Note: Indoor Location works in addition to Live View, allowing you to
analyse live data feeds from both indoor and outdoor devices, including signal strength,
battery status, and CPU usage.
Use Indoor Location to:
- View indoor devices in the Live View dashboard.
- Visually locate managed devices on an indoor map.
- View historical travel patterns.
- Create custom indoor maps using SOTI Design Studio.
This topic includes the following sections:
- Licensing and Prerequisites for Indoor Location
- Adding a Data Provider
- Editing and Deleting Data Provider
- Troubleshooting Data Providers
- Adding an Indoor Location
- Adding Multiple Indoor Locations to the Same Building
- Editing and Deleting an Indoor Location
- Using Design Studio to Create Indoor Map Images
