Editing and Deleting Data Provider
This topic describes how to edit data provider details or delete a data provider.
Navigate to the Live View Manage Locations panel and select a
data provider to edit or delete.
Select Live View from the main menu.
Select Manage Locations from the main menu.
- In the Manage Locations panel, select the Data Providers tab.
Hover over the entry of the data provider you wish to edit or delete and
right-click. In the pop-up menu select Edit to edit the
data provider or select Delete to delete it.
If you selected Edit, in the Edit Data
Provider panel, update the data provider settings.
Note: The data provider Name must be unique.
Select Save And Copy Webhook URL to save your
changes.
Note: You can regenerate the webhook details if required. Regenerated keys must be re-authorized in your data provider dashboard. Please see Adding a Data Provider for details on how to access your data provider dashboard and enter the values there.
