Live View
SOTI XSight Live View gives you visibility into a limitless range of business-critical intelligence collected from your fleet of mobile devices. With SOTI XSight Live View, you can gain a deeper understanding of your operations, reduce downtime, diagnose problems and even solve them before they happen.
Live View screen showing several devices on a map
SOTI XSight Live View collects real-time data recorded by your device fleet, at a collection frequency you select, then displays it as a map or a list. You can select any device and drill down to see all the data and events collected during the view session. What's more, SOTI XSight Live View includes the SOTI Time Machine tool that lets you see device activity at any point up to 72 hours prior.
SOTI XSight Live View collects data, such as location, signal strength and battery status, directly from the device. It can also retrieve and display data from business-critical apps of your choice using the following methods:
Method Description
SOTI Snap Automatic integration of custom apps data created using SOTI Snap.
XT Sock Smart Battery Plugin Integration of smart battery analytics using the XT Sock Smart Battery Plugin.
JSON file Integration of third-party app data using JSON files.
SOTI XSight Live View supports Android, Windows Modern and Linux platforms, and is compatible with SOTI MobiControl 15.6 and later (see System Requirements).
How To Series: How To Get Started with SOTI XSight Live View [VIDEO]
Feature Focus: Configuring SOTI XSight Live View [VIDEO]
How To: Build Data Connections Using SOTI Snap and SOTI XSight Live View Topics [VIDEO]
