Licensing and Prerequisites for Indoor Location
This section has the following information regarding the use of the Indoor Location feature.
Licensing
The Indoor Location feature requires the following:
  • SOTI MobiControl must be installed with an active license.
  • Devices must be enrolled in SOTI MobiControl.
  • Devices must have SOTI MobiControl Agent installed.
  • For Indoor Map, you must have one of the following:
  • For Data Provider Connection Type–using third party data provider integration:
  • For GPS connection type, special setup is not required.
Third Party Data Providers
Cisco Spaces
  • Licensing:
    • To implement indoor device tracking using Cisco Spaces, the Spaces ACT license is required. This license provides access to a comprehensive suite of location-based services, including asset tracking, occupancy monitoring, and environmental analytics. Licensing is typically based on the number of devices or the square footage of the area covered.
Note: Deploying a minimum of three Access Points is required for triangulation. Higher density and strategically placed access points result in better accuracy and more reliable data for indoor location tracking.
  • Wi-Fi Access Points deployed for the indoor environment:
Manufacturer Access Points
Cisco Access Points Cisco Catalyst 9100 Series (9115, 9117, 9120, 9130)
Cisco Aironet 4800 Series
Cisco Aironet 3800 Series (3802)
Cisco Aironet 2800 Series (2802)
Cisco Aironet 3700 Series (3702)
Cisco Aironet 3600 Series (3602)
Cisco Meraki Access Points Meraki MR Series (MR36, MR46, MR56, MR28, MR33, MR42, MR52, MR53, MR20, MR70, MR76, MR86, MR74, MR84)
Note: To connect Meraki Access Points, the same Cisco Spaces ACT license is required. For detailed instructions on connecting Meraki to Cisco Spaces, refer to Cisco's guide in the section 'Importing Cisco Meraki Locations Using the API Keys'.
Extreme Networks
  • Licensing:
    • To implement indoor device tracking using Extreme Networks' solutions, the ExtremeCloud IQ Pilot license is required. This license enables the management of access points, switches, and SD-WAN, providing real-time and historical monitoring, comprehensive troubleshooting, and integrated network applications.
    • For enhanced location services, such as asset tracking and analytics, the ExtremeCloud IQ CoPilot license is recommended. CoPilot offers advanced anomaly detection and capabilities to ensure the user experience of wireless and wired devices.
Manufacturer
Extreme Networks AP410C
AP460C
AP510C
AP560H
AP230
AP250
AP305C
AP310i/e
AP410e
Juniper Networks
  • Licensing:
    • To implement indoor device tracking with Juniper Mist AI, you can utilize the User Engagement service. The User Engagement service is available on a per-Access Point (AP) basis, allowing you to scale your deployment according to your organization's needs. To activate this subscription, you can contact MistRenewal@juniper.net to purchase the necessary licenses.
Juniper Networks (Juniper Mist) AP 21
AP 24
AP 33
AP 34
AP 41
AP 43
AP 45
AP 61
AP 63
BT11
Aruba Central
  • Licensing: To implement indoor device tracking using Aruba Central, the Aruba Central license is required. The Foundation License offers essential network management and monitoring capabilities, including basic location services. The Advanced License builds upon the Foundation License by adding advanced features, such as AI insights and enhanced location analytics.
Aruba Networks Aruba Series 300/500/600/700
Disabling MAC Randomization
Note: Disabling of MAC address randomization is available for both Android Classic and Android Enterprise devices.
  1. Disable MAC address randomization in SOTI MobiControl.
    Note: See the SOTI MobiControl topics, Wi-Fi (Android Classic) and Wi-Fi (Android Enterprise) for more information on configuring Wi-Fi on your devices when creating or editing a profile.
  2. Create a Profile in SOTI MobiControl. In the Configurations section under Connectivity, select Wi-Fi. Toggle Disable Mac Randomization on.
  3. Assign to the Device Group for Indoor Location Positioning.
