Current Watchlist Charts
This section lists the current watchlist charts.
Top X manufacturers
This chart shows the breakdown of manufacturers of devices that have reported data in this watchlist profile.
Calculation
Each segment shows the percentage of devices by manufacturer based on the Top X manufacturers.
Configurations
Dashboard users can change how many top manufacturers show on the chart. Changes to this dashboard are specific to the user and are not applied globally for all users.
Top X Models
Calculation
Each segment shows the percentage of devices by models based on the Top X models.
Configurations
Dashboard users can change how many top models show on the chart. Changes to this dashboard are specific to the user and are not applied globally for all users.
Top X OS Versions
Calculation
Each segment shows the percentage of devices by Android OS versions based on the Top X OS versions.
Configurations
Dashboard users can change how many top Android OS versions to show on the chart. Changes to this dashboard are specific to the user and are not applied globally for all users.
Watchlist Conditions
This chart shows the breakdown of watchlist entries between different conditions.
Calculation
Each bar shows the number of devices with each watchlist condition.
Days in Watchlist
This chart shows the distribution of watchlist entries based on how many days ago they joined the watchlist.
Calculation
Each bar shows the number of devices with a common entry date range:
  • 0: 0 hours to 23 hours
  • 1: 24 hours to 47 hours
  • 2: days is from 48 to 71 hours
  • 3: days is from 72 to 95 hours
  • 4: days is from 96 hours to 119 hours
  • 5: days is from 120 hours to 143 hours
  • 6: days is from 144 hours to 167 hours
  • 7+: days is from 168 hours and more
Days Since Check-in
This chart shows the days passed since last check-in for devices in watchlist for check-in. To access this chart, select Check-in from the conditions chart to cascade based on check-in.
Note: This chart is only be available if you have check-in set up as a condition.
Calculation
Each segment shows the percentage of devices grouped together based on their last days since check-in.
