Configuring Watchlists
This section describes how to create a watchlist profile.
                Select Watchlist from the main menu.
                Select Create New Profile from the
                        Profile dropdown.
 - Follow the steps below to create a new watchlist profile with the conditions customized to your needs.
                Enter a descriptive name and select a platform (Android or Windows).
                Select a SOTI MobiControl instance from the MobiControl
                        Instance dropdown.
                 In the Groups section, select Add
                        Groups.
                 Choose one or more groups and select Save.
                Select Next.
                In the Conditions to Monitor panel, select Add
                        condition.
                Select the condition type from the dropdown list.
Note: In this case, CPU was selected as the condition type, and the next step involves configuring parameters based on CPU conditions. Other condition types have different configuration parameters. - Select Next.
                In the Configure CPU popup panel, configure the parameters
                    for the CPU condition. If you selected a different condition type, the
                    parameters presented for configuration will be different.
                Note: The Display on Dashboard toggle should be set to On to see the condition in the dashboard.Note: The condition can still be used in combination with other conditions to create a combined condition, even if Display on Dashboard is toggled Off.Note: If you wish to send an email notification when the condition is true, Display on Dashboard' must be enabled.
 - Select Save.
                Add additional conditions by repeating steps 8 through twelve. With two or more
                    conditions defined, you can create combination conditions. In the screenshot
                    below, three conditions have been created. Select
                    Next.
                In the Combined Conditions to Monitor panel, you can
                    create a condition that is based on a combination of multiple singular
                    conditions. Select Add combined condition.
                Note: When combining conditions, the resulting combined condition is true only when all selected individual conditions are simultaneously met.
                In the Configure Combined Condition popup panel, enter a
                    Name for the combined condition and select two or more conditions. Select
                        Next.
                Note: The Check-In, Location and Monthly Data conditions are not available for creating a combined condition.
                In the Watchlist Email Notifications panel, select the
                    conditions or combined conditions to trigger an email notification. To cause
                    email notifications to be sent when the conditions are met, toggle
                        Email Notifications to On. In this example,
                    the singular condition Wi-Fi Signal, and the combined
                    condition Android Combined Conditions have been selected
                    for email notification. In the Send from field, enter the
                    email addresses to use as the sender of the notification email. In the
                        Send to field, enter the addresses of the recipients
                    of the notification emails.
 - Select Next.
