Creating Predefined Tags
Use this section to create tags and groups to organize them. The tags you create in this section are available to both administrators and non-administrators in the Tag field of the Incident Details view.
To define a new tag or tag group:
On the menu bar, select the menu button
and select Settings. The Settings view opens.
- On the left side of the Settings view, select Tags.
Select a group from the list or select
at the bottom of the Group column to add a new one.
- Type a new group name then select Save to save the group.
To add tags, select a group then select
at the bottom of the Tags column.
Type the name of the new tag then select Save to save
it.
Next steps: Set up groups
