Uploading the Certificate from SOTI MobiControl
- On the app page, under Manage, select Certificates & secrets.
- On the Certificates & secrets page, select Upload certificate.
- In the open dialog, browse to the self-signed certificate generated from SOTI MobiControl.
- Select Save when finished.
- When complete, select add. The certificate appears in the Certificates section.
- Close the current Certificates & secrets page and then the App registrations page to return to the main https://portal.azure.com/ page.
