The F5 SSL VPN profile configuration enables you to configure F5 SSL VPN settings for devices.
							| VPN Name |
							Enter the name of the VPN connection |
							| VPN Server Host Address |
							Enter the server hostname or IP address of the VPN connection |
							| Domain |
							Enter the domain of the VPN connection |
							| Username |
							Enter the username for authenticating the connection. You can use macros such as %EnrolledUser_Upn%, %EnrolledUser_Domain%, or %EnrolledUser_Username% . |
		Authentication
							| Authentication Type |
							Select the type of authentication used for this VPN connection. You can select Password or Certificate |
							| Password |
							If Password is selected, enter the password used for authentication |
							| Identity Certificate |
							If Certificate is used, select the certificate used for identity from the dropdown list. |
		Client Settings
							| FIPS-mode |
							Select the check box to enable FIPS (Federal Information Processing Standard) 140-2. |
