Authentication (Android Classic)
An Authentication configuration enables you to set minimum requirements for password-based user authentication on a device.
Device Administrator Password
Use this section to add an administrator password to the device. You must configure an administrator password before using various security features of SOTI MobiControl. The administrator password disables security feature such as lockdown and application run control, providing unrestricted access to the device.
| Password | Enter an administrator password for the device that disables security features such as lockdown or application run control. |
Device User Password Policy
Turn on User Password Policy to set complexity requirements and other password policies for the device user.
Note: You must specify a device administrator password before you can configure a user password policy.
		Minimum Complexity
| Password Quality | Select the minimum password quality. Password quality options are listed in order of security strength, from least to most secure. Device users can use any password type option that is more secure than the selected minimum.
| Password/PIN Length | Select the minimum password or PIN length. |
| Complex Characters | Select the minimum number of complex (non-alphanumeric) characters required. |
History
| Maximum Password Age | Turn on Maximum Password Age to enter the number of days before the user is prompted to enter a new password. |
| Unique Passwords Before Reuse | Turn on Unique Passwords Before Reuse to select the number of unique passwords a user must set before a previous password can be reused. |
Policy
| Screen Timeout | Turn on Screen Timeout to set a maximum inactive time before the screen locks. |
| Device Authentication Wipe Policy | Turn on Device Authentication Wipe Policy to select the number of times that an incorrect password can be entered before the device is automatically wiped. |
| Common Access Card (CAC) Authentication | Select this option to use Common Access Card (CAC) authentication. |
