| IKE Version |
							The IKE (Internet Key Exchange) version used for the VPN connection. |
							| Mobike |
							Enable MOBIKE (IKEv2 Mobility and Multihoming Protocol) for the VPN account if IKE version 2 is selected. |
							| Authentication Type |
							The type of authentication to be used. |
							| Pre-shared Key |
							The pre-shared key for this VPN connection. |
							| IPSec User Certificate |
							The user certificate used to authenticate against the IPSec VPN server. |
							| IPSec CA Certificate |
							The CA certificate used to verify the IPSec VPN server. |
							| IKE Phase 1 Exchange Mode |
							Select the IKE phase 1 exchange mode. |
							| Prefect Forward Secrecy |
							Use prefect forward secrecy for authentication. |
							| IKE Identity |
							The IPSec group ID type for the connection profile. |
							| Group Name |
							The IPSec group ID type value for the connection profile. |
							| Suite B Type |
							The Suite B type for the VPN connection. |
							| Diffie-Hellman Group |
							The Diffie-Hellman group for the connection profile. |
							| Split Tunnel Type |
							The Split Tunnel type for the VPN connection. |
							| Common Access Card Authentication |
							Use Common Access Card (CAC) for authentication. |
