Device Functionality
Features
| Allow Camera | When enabled, device user can use the camera.
									Android OS compatibility: 6.0 or later.  |
| Allow Smart Lock | When enabled, device users can use Smart Lock on Android which allows devices to unlock without a password when they are within 'safe' places that the device user sets.
									 If the Allow All Keyguard Features feature control option is enabled, Allow Smart Lock is automatically enabled too. Android OS compatibility: 6.0 or later.  |
| Allow Printing | When enabled, device users can use the device's printing capabilities.
									 Requires Android 9.0 or later.  |
| Allow Location Sharing for Work Profile | When enabled, Location Sharing is permitted for all Managed Profile apps. Apps running in the Work profile will be unable to use device location information. |
| Allow Skip App First Use Hints | When enabled, when a supported app launches for the first time, it will skip any introductory hints or tutorials. |
| Allow All Keyguard Features | When enabled, device users can use keyguard features on the lockscreen. Keyguard features include fingerprint authentication, viewing of notifications, smart lock access and camera access. Enabling Allow All Keyguard Features will automatically enable the other keyguard feature control options. |
| Allow Fingerprint Authentication | When enabled, device users can use Google's fingerprint authentication framework to secure their devices.
									 If the Allow All Keyguard Features feature control option is enabled, Allow Fingerprint Authentication will be automatically enabled too. Android OS compatibility: 6.0 or later.  |
| Allow Account Creation | Specify whether device users can add new accounts to the device. Choose an option from the dropdown list
 This does not remove any existing accounts from the device. All is selected by default.  |
| Allow Doze Mode | When enabled, allows the device to restrict the SOTI MobiControl Android agent for battery optimization.
									 Enter the package name of the VPN app.  |
| Perform SafetyNet Check on Device Check-in | When enabled, the SafetyNet check is performed on the device at every device check in, in addition to once daily. |
| Allow Copy/Paste between Work and Personal | When enabled, device users can copy text or images between the Work and Personal profiles. |
| Allow Sensitive Notifications | When enabled, notifications from Android Enterprise Apps display all their details when they appear on secure lock screens.
									 If the Allow All Keyguard Features feature control option is enabled, Allow Sensitive Notifications will be automatically enabled too. Android OS compatibility: 6.0 or later.  |
| Allow Third Party Input Methods | When enabled, device users can enable additional third-party input methods such as keyboards on their devices. |
| Allow Installation from Unknown Sources | When enabled, device users can install apps that are not from the Google Play store. |
| Allow Installation from Unknown Sources on Personal | When enabled, device users can install apps that are not from the Google Play store on the personal profile of the device.
									 Supported on Android 10.0 or later.  |
| Allow Sharing from Work Profile to Personal | When enabled, device users can use an app's Share function to share between apps on the Work profile to apps on the Personal profile.
									 Android OS compatibility: 5.1.1 or later.  |
| Allow Outgoing NFC | When enabled, devices users can use NFC to send data (only applies to apps in the Work Profile). |
| Allow Bluetooth Contact Sharing | When enabled, device users can use Bluetooth to share contact information.
| Allow Backup Service | When enabled, device users can turn control whether the backup service (which managers both backup and restore services) is turned on or off. |
Policy Messaging
Restriction Policy
Device Admin Description
Work Profile Wipe Message
Enter the message that should appear to device users when the Android Work Profile is wiped of its data and removed from the device.
Android OS compatibility: 9.0 or later.
