SOTI Surf
The SOTI Surf app is shut down (according to the delay set in Delay Application Update) and relaunched each time the SOTI Surf profile configuration is updated and assigned.
Home Screen
- If a device has multiple home screen websites enabled, the profile that was assigned first will supersede all others.
 - If a device has multiple home screen catalogs enabled, all websites from all profiles will be added to the catalog on the device.
 - If a device has a website and a catalog enabled, the home screen website will supersede the catalog.
 - If a device has a profile with the home screen enabled and another with it disabled, the enabled home screen will supersede the disabled setting.
 - Corporate bookmarks from multiple profiles will be unioned.
Turn on the Enable Home Screen toggle and you can control how the home screen of the SOTI Surf app appears to device users. Then choose either Catalog or Website.
Choose Catalog
- Choose Catalog if you want to provide a set of websites (as links on the home screen of the app. You can group links into folders.
 - Choose Website if you want the home screen of the app to be a single website.
| Websites | Add websites and they'll appear as links on the SOTI Surf home page.
								 Click New in the Websites table to add a new catalog entry. To delete a website, hover over its row and click Delete. Use the arrows to arrange the order in which the websites appear in the SOTI Surf home screen.  |
| Add Folders | Group websites into different folders. If you have a lot of websites, you can simplify the app home screen by placing websites links into folders.
								 Click New in the Add Folders table to create a new folder. On the Add Folders screen, enter a name for the folder and click New to add websites to the folder. Click OK once you've finished adding websites. You can add multiple folders and then arrange their order of appearance on the device screen.  |
| Show websites before folders in catalog | Turn on to show website links before folders on the home screen of the app. |
| Home screen URL | Enter the URL for the website that you want as the SOTI Surf home page. |
| Configure Corporate Bookmarks | Add websites as bookmarks to SOTI Surf. Click  New in the Configured Corporate Bookmarks table to create a new row. Enter a display name and the website's URL. Listed websites are added as corporate bookmarks.
								 To delete a bookmark, hover over its row and click Delete. Use the arrows to arrange the order in which the websites appear in the SOTI Surf bookmarks menu.  |
| Auto Hide Top and Bottom Bar | When enabled, device users cannot see or access the top and bottom bars of SOTI Surf. |
| Full screen mode | When enabled, SOTI Surf remains in full screen mode. |
| Text Scaling | Enter a percentage value from 50 - 200 to set the text size in the app.
								 Tip: On Android devices, you can also send a script to change the zoom level in the SOTI Surf app:
							sendinfo net.soti.action.surf BROWSERZOOMLEVEL 400 where 400 is a percentage value. |
| Restore tabs on startup | When enabled, tabs from a previous session are automatically loaded the next time the SOTI Surf app is launched. |
| Open links in new tab | When enabled, links are opened in a new tab instead of the current tab. |
| Open Files Automatically after Downloading | When enabled, files downloaded by the device user are automatically opened in the applicable app. |
| URL suggestion | When enabled, SOTI Surf suggests websites as the device user types in the address bar. |
| Download Location | The location on the device where SOTI Surf saves files downloaded from the internet. This option only applies to files downloaded from sites that are not routed through ERG. Downloads from sites routed through ERG are saved in an application sandbox.
								 The download location must be a location in the device's internal storage, for example, %sdcard% or a defined directory path. Directory paths cannot begin or end with  Note: To save downloads to the root level, leave the download location field blank.
								If a device has multiple profiles with conflicting download location settings, settings from the profile that was created first will be used.  |
| Hide Reset Settings | When enabled, device users cannot see or access the Reset Settings option in the SOTI Surf app. |
| Browsing on Cellular | When enabled, the SOTI Surf app can use cellular networks. |
| Roaming | When enabled, the SOTI Surf app can use cellular networks while roaming. |
| WiFi | When enabled, the SOTI Surf app can use WiFi networks. |
| Export browsing history | Enable this option and then, in the File Location field, enter a location on the device's internal storage where you want to store browser history from the SOTI Surf app.
								 If a device has multiple profiles with conflicting file location settings, settings from the profile that was created first will be used.  |
| Use LDAP Login | When enabled, devices users must use their LDAP credentials to log into SOTI Surf. You must have intranet gateway settings configured to use this option.
								 Specify the user inactivity time (in minutes), after which the user will be logged out. Enter 0 to disable inactivity timeout for the browser. If a device has been assigned multiple SOTI Surf configurations with conflicting Enable LDAP Login settings, the configuration with LDAP enabled applies. If multiple SOTI Surf configurations have LDAP enabled but with differing inactivity timeouts, the timeout period specified in the configuration that was applied first supersedes the subsequent configurations.  |
| Delay Application Update | Specify the time (in minutes) between when a configuration change is pushed to the device and when the app is forced to shut down and apply the update, requiring device users to log in again. Devices will automatically relaunch once the update has been applied.
								 If a device has been assigned multiple SOTI Surf configurations with conflicting app shutdown times, the configuration that was created first applies.  |
Privacy
| Disable Copy from Browser | When enabled, devices users cannot copy content from within browser - both to other web pages and to apps outside of the browser.
								 Note: Enabling this option also enables Disable Screen Capture when Browsing and Disable Sharing of Downloaded Files. Both options can be subsequently disabled without also disabling Disable Copy from Browser.
| Disable Screen Capture when Browsing | When enabled, device users cannot take screenshots of their device screen while SOTI Surf is the active app. |
| Disable Downloading of Files | When enabled, device users cannot download any files from within the SOTI Surf app.
								 Note: Enabling this option also enables the Disable Sharing of Downloaded Files setting though it can be deselected independently of Disable Downloading of Files.
| Disable Sharing of Downloaded Files | When enabled, device users cannot share any files they have downloaded in SOTI Surf with another person or another app. |
| Restrict File Types | Enter file extensions for the files types that you want to block device users from downloading. Separate file extensions with a comma.
								 For example:   |
| Disable Printing | When enabled, devices users cannot print any content from within the browser.
								 Note: Disable Printing does not disable Cloud Printing on sites such Gmail, where printing options are available.
| Disable JavaScript | When enabled, JavaScript does not run on any web pages.
								 Note: Device users may experience significant limitations when navigating the internet due to the prevalence of JavaScript.
| Disable Popups | When enabled, SOTI Surf prevents websites from opening any popup windows. Websites that use alerts or confirmation boxes are allowed but any websites that call new web pages are blocked. |
| Disable Cookies | When enabled, websites cannot store any cookies on SOTI Surf. |
| Clear Cookies on Launch | When enabled, cookies from previous browser sessions will be cleared when the browser is relaunched.
								 Note: Clear Cookies on Launch can be enabled independently of Disable Cookies.
| Disable Third Party Cookies | When enabled, cookies from third-party domains (that is, domains beyond the site the user is currently visiting) are blocked on SOTI Surf. |
| Disable Website Cache | When enabled, the browser does not cache website data when the app closes or the user navigates away from a web page. |
| Disable Auto Fill | When enabled, web pages with forms or fillable fields do not remember any previously entered information. |
| Disable Safe Search | When enabled, the safe search filter (that is normally active on SOTI Surf) to block inappropriate or explicit images and videos is turned off. Device users can access all web content - if it is not blocked by other web filtering settings. Disable safe search applies to search results only.
								 Note: Disable Safe Search is more restrictive when it is unchecked.
| Disable Access to Websites with invalid SSL certificate | When enabled, device users cannot access websites with SSL security certificate errors. |
| Disable Invalid SSL Certificate Warnings | When enabled, warnings about invalid SSL certificates are not shown to device users.
								 Note: This may lead to data security issues.
								You cannot use this option if Disable Access to Websites with invalid SSL certificate is turned on.  |
| Open new tab in background | When enabled, when a device user clicks a link to open it in a new tab, the new tab will always open in the background.
								 Note: If multiple profiles are assigned to a device but have conflicting tab opening settings, the setting of the profile that was created first will apply.
| Clear History on Launch | When enabled, when the SOTI Surf app is launched, the browsing history from previous sessions is cleared.
								 Note: If multiple profiles are assigned to a device but have conflicting clear history on launch settings, the profile with the setting enabled will apply.
| Disable Bookmarks | When enabled, device users cannot save webpages as new bookmarks or edit existing bookmarks in the SOTI Surf app.
								 Note: If multiple profiles are assigned to a device but have conflicting disable bookmarks settings, the profile with the setting enabled will apply.
| Open Files in Third Party Applications | When enabled, devices users can open files that are unsupported by the SOTI Surf editor in third party applications instead. Open Files in Third Party Applications is more restrictive when disabled; devices with conflicting settings will use the disabled setting and block the opening of files in third party applications. |
| Disable Zoom Gestures | When enabled, devices users cannot use gestures to zoom in and out in web pages. |
| Set Browser Zoom Level | Set the default magnification for all websites displayed in the SOTI Surf browser. The zoom level can be set from 50% to 500%. 100% is the standard zoom level. |
| Disable Media Auto-play | When enabled, videos and audio clips are prevented from automatically starting playback. Muted videos, however, are still auto played. |
| Hide Address Bar | When enabled, the address bar in the SOTI Surf browser is hidden, preventing device users from manually entering or editing website URLs, thus restricting user access to websites in the Home screen catalog. |
| Search Engine | Select a default search engine for SOTI Surf. Any searches initiated from the address bar are run through the specified search engine.
								 If a device has been assigned multiple profiles that have conflicting settings, the search engine from the profile that was assigned first will apply.  |
Filtering
Intranet Gateway Settings
Website Restrictions
Kiosk Mode
Kiosk mode limits SOTI Surf functionality, reducing device users' access to websites and SOTI Surf app settings. The address bar is disabled, and users can only navigate forward through hyperlinks and backwards using the back button. The long-press context menu is also disabled.
| Hide App Bottom Bar | When enabled, device users cannot access the bottom bar of the SOTI Surf app, which includes the forward and backward navigation buttons, as well as the home and the app menu icons.
								 Selecting this option causes the Hide App Menu and Clear Cookies with Home options to become automatically selected.  |
| Hide App Menu | When enabled, device users cannot access the app menu. |
| Clear Cookies with Home | When enabled, browser cookies are cleared whenever the device user navigates to the home screen.
								 Note: This option is redundant if Disable Cookies is selected in the Configure Privacy Settings section.
| Disable Keyboard | When enabled, device users cannot display the keyboard, for example when they tap on a text field.
								 Note: Device users can use the keyboard to log in, after which it becomes disabled.
