Email: Exchange Active Sync
The Exchange Active Sync email configuration enables you to configure Microsoft Exchange email settings for your devices.
Connection
Account Name Specify Account Name or Description
User Active Directory User. The following characters cannot be entered here: / \ [ ] : ; | = + * ? < > " @
Domain Network domain name.
Server IP Address or hostname for the Exchange server.
Note: This field is case-sensitive.
Server Path Prefix Prefix to be added to server path. Optional.
Client Certificate Select the client certificate from the list.
Mail
Sync the Past Synchronize all calendar entries for the future, and for the past specified amount of time.
Sync Interval Frequency of synchronization.
Allow HTML Allow email in HTML format.
Email Size Maximum amount of data for email message body to fetch during synchronization.
Email Configuration Specify the email address for the device. Supports macros.
Sender Name Specify the name of the Exchange account.
Signature String to be used as the signature of the sender.
Email Notification Choose what to do for email notification.
Security Choose whether to use none, SSL or TLS security
Common Access Card Authentication Select this option to enable Common Access Card for authentication.
Calendar
Sync Calendar Synchronize all calendar entries for the future, and for the past specified amount of time.
Synchronization
Always Sync Always sync or use sync schedule specified.
Peak Start Time Specifies the beginning peak service period for peak days.
Peak End Time Specifies the end peak service period for peak days.
Peak Schedule Peak schedule Synchronization frequency during peak times. Select 'As items arrive' for real-time email delivery.
Off-peak Schedule Synchronization frequency outside of peak times. Select 'As items arrive' for real-time email delivery.
Peak Days - Sunday Select to include this day in the peak time schedule.
Peak Days - Monday Select to include this day in the peak time schedule.
Peak Days - Tuesday Select to include this day in the peak time schedule.
Peak Days - Wednesday Select to include this day in the peak time schedule.
Peak Days - Thursday Select to include this day in the peak time schedule.
Peak Days - Friday Select to include this day in the peak time schedule.
Peak Days - Saturday Select to include this day in the peak time schedule.
While Roaming Select this option to maintain automatic synchronization even when the device is using a roaming data service.
