APN
| Display Name | Enter a name for the APN that is displayed on the device. |
| Access Point Name (APN) | Enter the name or web address of the access point provided by your wireless carrier. |
| Mobile Country Code (MCC) | Select the three digit code, as defined by the ITU, that identifies the network's country of origin. |
| Mobile Network Code (MNC) | Select the mobile network code. The list contains all available mobile networks in the selected country.
								 This option only appears after a Mobile Country Code is selected.  |
| Access Point Type | Select the access point type. |
| Access Point Custom Type | Enter the custom access point type.
								 This option only appears if Any Type is selected as the Access Point Type.  |
| MVNO Type | Select the type of mobile virtual network operator (MVNO). |
| MVNO Value | Enter a value for the mobile virtual network operator (MVNO).
								 This option only appears after a MVNO Type is selected.  |
| Default Connection | Select this option to make this the default APN connection for devices. |
Server
| Access Point Connection Username | Enter the APN username provided by your wireless carrier. |
| Access Point Connection Password | Enter the APN password provided by your wireless carrier. |
| Host Address | Enter the hostname or IP address and port number of the server provided by your wireless carrier. |
| Proxy Server Address | Enter the hostname or IP address of the proxy server. |
| MMS Proxy Server Address | Enter the MMS proxy server address provided by your wireless carrier. |
| MMS Server Address | Enter the MMS server address provided by your wireless carrier. |
| Authentication Type | Select the type of authentication used for the APN connection. |
