Jump to main content
SOTI Online Help Home Page
SOTI XSight Help
Important: This site is an archive of Help for older releases and is no longer updated.
For the latest Online Help, visit SOTI Pulse.
Visit Support Page
  • Welcome to SOTI XSight 2025.1.0
  • What's New in SOTI XSight Help
  • Installation
  • Setting Up SOTI XSight
  • Operational Intelligence
  • Live View
  • Watchlists
  • Incident Management
  • Manage Shared Topics
  • Generate XSight Agent
  • Sync MobiControl Info
  • Roles and Permissions
  • Using the Self Service Portal
  • Diagnostics and Remote Control
  • Using the SOTI XSight Administration Utility
  • Logging Out
  • Glossary
  • Notices
  1. Home
  2. Operational Intelligence
  3. Device Analysis Dashboards Overview
  4. Application Dashboards
  • Installation
    • Creating an Analysis Profile
    • Filtering and Searching for Device Data
    • Charts Common to all Device Analysis Dashboards
      This section contains information that applies to all device analysis dashboards.
    • Setting Custom Attributes for Devices
    • Device Analysis Dashboards Overview
      • Application Dashboards
        • App Usage
        • App Usage - Shift
        • App List
        • Web App Usage
        • Web App List
      • Network/Data Dashboards
      • Battery Status Dashboard
      • Last Location
      • Device List
    • Smart Battery Dashboards and Pools Overview
    • Device Spotlights Overview
    • App Spotlight
      The App Spotlight provides information about the applications running on devices. For example, the number of times an app was opened, the amount time of an application runs in the foreground across devices, and the upload/download data usage of an application.
    • Managing Shifts
    • Managing Reports
    • Managing Rated Capacity
      Override a device's rated battery capacity value to get more accurate readings and measurements for analysis. SOTI XSight can provide estimated rated capacity values for devices that are generally more accurate than those provided by the manufacturer (see operational_intelligence/device_analysis_dashboards/battery_status_dashboard.html). After deploying a device and allowing its characteristics to stabilize, use the estimated rated capacity value provided by SOTI XSight to override a manufacturer’s rated capacity value.
    • Managing App Mappings
      Create app categories and app mappings that you can link to a specific category.
    • Managing Web App Mappings
      Create web app categories and web app mappings that you can link to a specific category.
    • Operational Intelligence Heatmap Data Reference
    • Personal Shopper Utilization
      SOTI XSight Personal Shopper Utilization provides insight into the life cycle of each Personal Shopper device. Personal Shopper Utilization receives data from the SOTI Personal Shopper Application and provides the data needed to reduce idle time, streamline device circulation, and monitor usage trends, maximizing the value of your Personal Shopper devices.
  • Live View
  • Watchlists
  • Logging Out
  • Glossary
  • Notices
Application dashboards display information about installed applications, such as apps used during a shift and the top visited apps. See the Device Analysis Dashboards Overview section for information on Accessing and Customizing a Device Analysis Dashboard.
The following application dashboards are available:
  • App Usage
  • App Usage - Shift
  • Web App Usage
  • App List
  • Web App List
Related information
