Managing Rated Capacity
Override a device's rated battery capacity value to get more accurate readings and measurements for analysis. SOTI XSight can provide estimated rated capacity values for devices that are generally more accurate than those provided by the manufacturer (see Battery Status Dashboard). After deploying a device and allowing its characteristics to stabilize, use the estimated rated capacity value provided by SOTI XSight to override a manufacturer’s rated capacity value.
Accessing the Manage Rated Capacity Panel
- Log into the SOTI XSight web console as administrator.
From the main menu, select Operational Intelligence.
- Open the main menu again.
Select Manage Rated Capacity.
Adding a Rated Capacity Override
- In the Manage Rated Capacity panel, select the Add icon.
- In the Add New Rated Capacity for Device panel, enter
values for Device Manufacturer, Device
Model and Rated Capacity (mAh).Note: The Rated Capacity (mAh) value must not be lower that the estimated rated capacity reported in SOTI XSight.
- Select Add.
- In the Manage Rated Capacity panel, the newly added rated
capacity value for the device appears.
Select Save to save your changes.
Deleting a Rated Capacity Override
Follow steps 1 through 4 above in Accessing the Manage Rated Capacity Override.
- Hover over the row containing the rated capacity override you wish to delete.
- The Delete icon appears in the row. Select the Delete icon.
- Confirm the deletion of the rated capacity
override.
- In the Manage Rated Capacity panel, select Save to save your changes.
