Connecting On-Premises SOTI MobiControl with SOTI Identity
In SOTI MobiControl version 15.5.x and earlier, SOTI MobiControl called SOTI Identity APIs in a one-way communication model. This function was the same whether SOTI MobiControl was hosted on-premises or cloud-based.
In SOTI MobiControl version 15.6 and later, role management and assignment has moved to SOTI MobiControl and the communication model is now two-way. To synchronize data, SOTI Identity must call SOTI MobiControl SCIM APIs. If SOTI MobiControl is hosted on-premises or on cloud and does not allow calls from outside, synchronization with SOTI Identity will fail.
You must whitelist connections originating from SOTI Identity. On-premises SOTI MobiControl can
communicate with SOTI Identity through Port 443 and
through http: endpoint. Organizations using IP-based firewalls must whitelist
the following IP addresses for SOTI Identity to
communicate with SOTI MobiControl version 15.6 and later:
Identity Outgoing IP for EU Region:
3.124.161.5 -
Identity Outgoing IP for US Region:
3.231.183.31
