Settings Manager | Configuration Details
Use Settings Manager to permit the use of specified device settings when a device is in lockdown mode. See Using Settings Manager. Choose from the following device settings when configuring the Settings Manager app using the Settings Manager profile configuration. Do this when you perform the following actions:
| Setting in Profile Configuration | Details |
| Description | Specifies the name of the Settings Manager configuration. This
name is used as the description for the payload. Important: The description must not
contain any of the following characters: ' " `
Accessibility
| Setting in Profile Configuration | Details | Setting In XML Configuration |
| Enable | Allow device users to manage accessibility settings. Note: This setting does not apply to
tablets. |
manageAccessibilityOnOff |
Display
| Adaptive Brightness | Control the adaptive brightness setting for the device. | brightnessSeek |
| Brightness | Set the brightness level of the display. | brightnessAuto |
| Screen Rotation | Set the display to remain in portrait mode persistently or rotate automatically as the device changes position. | AutoRotate |
| Screen Timeout | Set a period after which the device screen times out and goes to sleep. | screenTimeout |
Sound
| Ringtone Volume | Control the volume of the ringtone on the device. | ringtoneVolume |
| Media Volume | Control the volume of any media they play on the device. | mediaVolume |
| Notification Volume | Adjust the volume of notifications on the device. | notificationVolume |
| System Volume | Control the volume of the device. | systemVolume |
WiFi
| Enable | When enabled, the device user has access to Wi-Fi connectivity settings. | wifiOnOff |
| Scan | When enabled, the device can scan for available Wi-Fi networks. | wifiScan |
| Add | When enabled, the device user can add new Wi-Fi networks. | wifiAdd |
| Modify | When enabled, the device user can change Wi-Fi network settings. | wifiModify |
Mobile Data
| Enable | When enabled, the device user has access to device cellular data settings. | configureMobileDataOnOff |
Bluetooth
| Enable | When enabled, the device has access to Bluetooth. | btOnOFf |
| Visible | When enabled, the device is visible to other Bluetooth enabled devices. | btMakeVisible |
| Pair | When enabled, the device can pair with other Bluetooth enabled devices. | btPairUnpair |
| Scan | When enabled, the device can scan for other visible Bluetooth enabled devices. | btScan |
Time Zone
| Enable | When enabled, the device has access to the Time Zone. | timeZoneOnOff |
| Manual Sync to SNTP server | When enabled, the device can synchronize with the SNTP server to manually update the date and time. | syncWithSntpServer |
| SNTP Server | The device can synchronize and update the date and time according to the defined server. | sntpServer |
Manage Access Point Name
| Manage Access Point Name | When enabled, the device user can create, change, view and delete the APNs. | manageAccessPointNameOnOff |
Manage Device Security
| Manage Device Security | When enabled, the device user can set a new PIN or password. | manageDeviceSecurityOnOff |
Flashlight
| Flashlight | When enabled, the device user can use device flashlight. | flashlightOnOff |
