Cloning a Report Schedule
To save time you can create a new report schedule by creating a copy of an existing schedule and modifying it.
To create a copy of a report schedule:
  1. From the SOTI MobiControl web console main menu, select Reports.
  2. In the left pane, select the report type under Report Categories. The report details appear in the right pane.
    Note: You can search the report you want by selecting Search. You can also filter the Report Categories by device family type.
  3. In the right pane, right-click on the report schedule. Select Clone.
    Clone button
    A new copy of the Schedule Report wizard opens.
  4. In the Schedule Report wizard, make the desired edits to the schedule - see Create/Edit Schedule for Report for more information about the tabs.
  5. Select Finish to save the schedule changes.
The new copy of the report schedule appears in the Schedule section.
