Deleting a Report Schedule
To delete a report schedule:
- From the SOTI MobiControl web console main menu, select Reports.
In the left pane, select the report type under Report
Categories. The report details appear in the right pane.
Note: You can search the reports by selecting Search. You can also filter the Report Categories by device family type.
In the right pane, right-click on the report schedule. Select
Delete.
A confirmation dialog box opens to confirm that you want to delete the schedule.
- Select Delete.
The selected report schedule is now deleted.
