Accessing the Report Generation Queue
You must generate a report to enable the report generate queue. See Generating a Report to gain acess to the report generation queue.
The report generation queue maintains all reports generated in SOTI MobiControl. Only the user that generated the report and administrators can perform actions on reports.
Reports are available to download for 24 hours after generation.
  1. From the SOTI MobiControl web console main menu, select Reports.
  2. In the left pane, select Report Queue.
    Report Queue button
    The Report Generation Queue dialog box opens.
You have access to the Report Generation Queue to view and download reports.
