Disabling a Report Schedule
To disable a report schedule:
  1. From the SOTI MobiControl web console main menu, select Reports.
  2. In the left pane, select the report type under Report Categories. The report details appear in the right pane.
    Note: You can search the reports by selecting Search. You can also filter the Report Categories by device family type.
  3. In the right pane, right-click on the report schedule. Select Disable.
    Clone button
The selected report schedule is now disabled. If other schedules have been created for this report type, those schedules are not affected.
To re-enable a disabled report schedule, right-click on the schedule and select Enable.
