Activation Lock Bypass Code Status
The following table defines the possible values for the Activation Lock Bypass Code Status field for iOS/macOS devices.
Code Available (Apple Verified) | The Bypass Activation Lock Code exists on the server and was retrieved during the current enrollment. |
Code Available (MobiControl Verified) | The Bypass Activation Lock Code exists on the server and was retrieved during a past enrollment. |
Code Unavailable | The Bypass Activation Lock Code is not present on this SOTI MobiControl instance. Note: The Bypass Activation Lock Code field
does not display. |
Code Used | The Activation Lock Bypass Code successfully bypassed the
activation lock. See Bypassing the Activation Lock. Note: The Code Used status is not
applied when bypassing the Activation Lock
manually. |
Not Applicable | The device is not supervised and uses macOS below version
10.15. Note: The Bypass
Activation Lock Code field does not
display. |
