Building Signal Policy Conditions
Review the following video and procedure to learn how to add conditions to your Signal policy.
In the Conditions step of the Signal wizard, click Add
Condition to build your first condition within your first
condition group.
- Repeat step 1 to add additional conditions as necessary. The Category for subsequent conditions is locked to the same Category as your first condition.
If you have added more than one condition, you can change the
conditions must be satisfied drop-down to:
- ALL: All of the conditions listed must be evaluated to be true for
the Signal Policy to trigger. This sets up an AND-style condition set.
For example: (Device Battery < 10%
ANDDevice Memory < 1 GB) - ANY: Any of the conditions listed must be evaluated to be true for
the Signal Policy to trigger. This sets up an OR-style condition set.
ORDevice Memory < 1 GB)
- Click New Group to add a new group of conditions that will work together with the conditions you have already added. Subsequent groups can feature different Categories.
If you have added more than one Group, you can set the Grouped
Conditions to Trigger Actions Must Include drop-down to ANY or
ALL in a similar way as described in step 3. For example, if you have two
condition groups :
- Selecting ANY sets up an OR-style condition set between the condition groups: [(A AND B AND C) OR (D AND E)]
- Selecting ALL sets up an AND-style condition set between the condition groups: [(A OR B OR C) AND (D OR E)]
- Click Next to add Actions to your policy, as described in Adding Signal Policy Actions.
